跳转到主内容
Eco X Gear LED Display Replacement
你所需要的
  1. Eco X Gear LED Display Replacement, Frame: 步骤 1 中的图像 1,1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: 步骤 2 中的图像 1,1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: 步骤 3 中的图像 1,1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: 步骤 5 中的图像 1,1
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: 步骤 6 中的图像 1,1
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
结论
James Lipsett
于03/20/17注册
625 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 146
