跳转到主内容
Eco X Gear Battery Replacement
你所需要的
  1. Eco X Gear Battery Replacement, Frame: 步骤 1 中的图像 1,1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: 步骤 3 中的图像 1,1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: 步骤 6 中的图像 1,2 Eco X Gear Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: 步骤 7 中的图像 1,1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: 步骤 8 中的图像 1,1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: 步骤 9 中的图像 1,1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
结论
另外一个人完成了本指南。
James Lipsett
于03/20/17注册
625 声望
创作了6篇指南
团队
3条评论
Where to get the new battery?
James Chen - 回复
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 27
总计 678
