简介
This guide is used when the toggle button is no longer functioning properly. If you are experiencing a loose or broken toggle button it must be replaced to keep the device operating normally.
你所需要的
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Use the angled tweezers to disconnect the toggle button covering.
即将完成!
结论
