跳转到主内容
Eclipse MTE28VGM Plastic Casing Replacement
你所需要的
  1. Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: 步骤 1 中的图像 1,3 Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: 步骤 1 中的图像 2,3 Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: 步骤 1 中的图像 3,3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Plastic Casing Replacement: 步骤 2 中的图像 1,3 Eclipse MTE28VGM Plastic Casing Replacement: 步骤 2 中的图像 2,3 Eclipse MTE28VGM Plastic Casing Replacement: 步骤 2 中的图像 3,3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Plastic Casing Replacement: 步骤 3 中的图像 1,3 Eclipse MTE28VGM Plastic Casing Replacement: 步骤 3 中的图像 2,3 Eclipse MTE28VGM Plastic Casing Replacement: 步骤 3 中的图像 3,3
    • Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
    • Remove the motherboard from the front plastic cover and screen.
    • Install new plastic case following steps in reverse order
结论
DELETED
于10/13/16注册
252 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Fall 2016 IUPUI, Team 2-1, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 188
