跳转到主内容
Eclipse MTE28VGM Lens Cover Replacement
你所需要的
  1. Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 1,3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 2,3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 3,3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Lens Cover Replacement: 步骤 2 中的图像 1,3 Eclipse MTE28VGM Lens Cover Replacement: 步骤 2 中的图像 2,3 Eclipse MTE28VGM Lens Cover Replacement: 步骤 2 中的图像 3,3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Lens Cover Replacement: 步骤 3 中的图像 1,2 Eclipse MTE28VGM Lens Cover Replacement: 步骤 3 中的图像 2,2
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
结论
Tyler Hudgens
于09/29/16注册
288 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Fall 2016 IUPUI, Team 2-1, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 171
