跳转到主内容
Eclipse 180G2 Outer Case Replacement
你所需要的
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,2 Eclipse 180G2 Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: 步骤 2 中的图像 1,3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: 步骤 2 中的图像 2,3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: 步骤 2 中的图像 3,3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
结论
3等其他人完成本指南。
Jesse Minor
于01/15/15注册
662 声望
创作了3篇指南
团队
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G4
4 名成员
创作了5篇指南
一条评论
What if there is no charge port or USB port there no longer?
May 303 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,330
