跳转到主内容
Eclipse 180BL Touch Pad Replacement
你所需要的
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: 步骤 1 中的图像 1,1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: 步骤 2 中的图像 1,3 Eclipse 180BL Touch Pad  Replacement: 步骤 2 中的图像 2,3 Eclipse 180BL Touch Pad  Replacement: 步骤 2 中的图像 3,3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
结论
另外一个人完成了本指南。
Thomas Schwarz
于09/07/15注册
499 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 650
