跳转到主内容
Eclipse 180BL LCD Screen Cover Replacement
你所需要的
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 1,3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 2,3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 3,3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: 步骤 2 中的图像 1,3 Eclipse 180BL LCD Screen Cover Replacement: 步骤 2 中的图像 2,3 Eclipse 180BL LCD Screen Cover Replacement: 步骤 2 中的图像 3,3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
结论
Thomas Schwarz
于09/07/15注册
499 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 515
