简介
When the underlying issue is revolved around the Wire port you can follow these steps on how to replace it. *Note that when replacing your Wire port, you are replacing the entire motherboard because they are attached. The only tool you will need is a #1 Phillips head screwdriver.
你所需要的
Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
结论
