简介
If your camera is working, but your monitor won't turn on, the issue is probably with your motherboard. In this guide shows you step by step instructions on how to replace your motherboard. The only tool you will need is a #1 Philips head screwdriver.
你所需要的
Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
Don't lose your screws!
即将完成!
结论
