跳转到主内容
EchoMaster MRC-WLP43 Camera Replacement
你所需要的
  1. EchoMaster MRC-WLP43 Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Unscrew the two silver 1.4 mm Phillips #1 screws connecting the metal bar to the camera.
    • Don't lose your screws!
  2. EchoMaster MRC-WLP43 Camera Replacement: 步骤 2 中的图像 1,1
    • Take the two tabs off the sides of the camera by unscrewing the four 1.2 mm Phillips #1 screws connected.
    • Don't loose your screws!
  3. EchoMaster MRC-WLP43 Camera Replacement: 步骤 3 中的图像 1,2 EchoMaster MRC-WLP43 Camera Replacement: 步骤 3 中的图像 2,2
    • When the screws are out, pop the two tabs off the sides.
    • Then you can pull off the back panel. You will then be left with the camera and wires. To install the new camera simply retrace these steps.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 309
