跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide to replace all the fuel lines, grommet, fuel filter, ventilator, purge bulb and gas cap vent gasket. All of these parts come in a Echo Fuel Line Repower Kit.
  1. Make sure to empty any gas in the tank into an appropriate container before beginning to work on equipment. Twist knob on air filter counter clockwise and remove.
    • Make sure to empty any gas in the tank into an appropriate container before beginning to work on equipment.
    • Twist knob on air filter counter clockwise and remove.
  2. Disconnect fuel lines from carburetor by pulling firmly. After lines are disconnected, pry grommet from the gas tank. This can be done with a flat head screwdriver as shown or a pair of plyers. After lines are disconnected, pry grommet from the gas tank. This can be done with a flat head screwdriver as shown or a pair of plyers.
    • Disconnect fuel lines from carburetor by pulling firmly.
    • After lines are disconnected, pry grommet from the gas tank. This can be done with a flat head screwdriver as shown or a pair of plyers.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. It is going to be a tight fight so a little oil or  grease on the grommet will help it to slide in a little easier. Insert the fuel filter through small hole in the gas tank. Use fingers to reset grommet into the fuel tank. It can be tough but it will squeeze in with enough effort.
    • It is going to be a tight fight so a little oil or grease on the grommet will help it to slide in a little easier.
    • Insert the fuel filter through small hole in the gas tank.
    • Use fingers to reset grommet into the fuel tank. It can be tough but it will squeeze in with enough effort.
  5. Attach the black line firmly to the hose attachment towards the inside. Attach the yellow line firmly to the outer hose attachment. The black hose with the white attachment slides right into the area circled in the picture.
    • Attach the black line firmly to the hose attachment towards the inside.
    • Attach the yellow line firmly to the outer hose attachment.
    • The black hose with the white attachment slides right into the area circled in the picture.
  6. Loosen the two screws holding on the carburetor with a stardrive bit turning it counter clockwise. The pictures show the airfilter housing removed. This is not necessary or recommended and only done to take better pictures. Remove the four screws holding on the old purge bulb by turning counter clockwise.
    • Loosen the two screws holding on the carburetor with a stardrive bit turning it counter clockwise.
    • The pictures show the airfilter housing removed. This is not necessary or recommended and only done to take better pictures.
    • Remove the four screws holding on the old purge bulb by turning counter clockwise.
    • Remove plate holding on purge bulb.
    • Old purge bulb should come right out and replace it with the new.
  7. Unscrew and remove gas cap. The plastic piece bends that keeps it attached and will pull out of tank. Pry old gasket out with screw driver or needle nose plyers.
    • Unscrew and remove gas cap. The plastic piece bends that keeps it attached and will pull out of tank.
    • Pry old gasket out with screw driver or needle nose plyers.
    • Replace with new gasket using fingers to position it.
结论
5等其他人完成本指南。
Michael
于2014年10月11日注册
251 信誉积分
撰写一个指南
团队
USF Tampa, Team 1-20, Donnelly Fall 2014 USF Tampa, Team 1-20, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G20
1 名成员
创作了1篇指南
Thank you so much!!! Helped me a lot!
dutra - 回复
Really good information thanks.
billyboy0902 - 回复
添加评论
浏览统计数据:
过去的24小时: 11
过去的7天: 88
过去的30天: 422
总计 14,667
