跳转到主内容
Echo Dot 3 Mic/LEDs/Button Replacement
你所需要的
  1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: 步骤 1 中的图像 1,2 Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: 步骤 1 中的图像 2,2
    • Turn your Dot around, so that the Barcode is facing up, and the buttons down.
  2. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": 步骤 2 中的图像 1,2 Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    • Using a Spudger remove the Lid.
    • There's Adhesive under the lid, so the best way to get it off, is to go all the way around with the Spudger
  3. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 步骤 3 中的图像 1,3 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 步骤 3 中的图像 2,3 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    TR6 Torx Security Screwdriver
    $5.99
    • Unscrew the 4 T6 Torx screws using the Right Screwdriver
    • After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
  4. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 步骤 4 中的图像 1,3 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 步骤 4 中的图像 2,3 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 步骤 4 中的图像 3,3
    • Unscrew the 3 T6 Torx screws,
    • and lift the flex cable connector.
    • After that, very carefully remove the PCB/Power supply (no idea).
  5. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: 步骤 5 中的图像 1,2 Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: 步骤 5 中的图像 2,2
    • Remove the 4 T6 Torx screws (2 different lengths!)
    • Slowly Remove the Middle part
    • Be very careful while removing the middle part, so that you don't damage the cable!
  6. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 步骤 6 中的图像 1,3 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 步骤 6 中的图像 2,3 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 步骤 6 中的图像 3,3
    • Remove the 4 T6 Torx screws,
    • and lift the plastic to remove it.
  7. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 步骤 7 中的图像 1,3 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 步骤 7 中的图像 2,3 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Simply flip the device to separate the:
    • Motherboard and
    • Buttons from each other.
结论
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
2等其他人完成本指南。
ashlynn
于05/10/22注册
190 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 815
