当前版本的文档还未经巡查,您可以查看最新的已查核版本。
在这个步骤中使用的工具:
Anti-Static Wrist Strap
$7.95
购买
Locate the 7 screws holding the back cover on.
Three screws are located on the bottom of the camera.
Two screws are located on the side shown in the photograph.
Two final screws are located on the opposite side shown in the photograph.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Use plastic opening tools to slightly open the side of the case.
Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
The first two are near the words "3X Optical Zoom".
The third is near the shutter button.
Gently pull apart the back cover from the rest of the camera.
Make sure there are no more screws or tabs keeping the cover on.
Use the plastic opening tool to separate any sides still closely connected.
Once the front cover is removed, the battery door maybe closed for convenience.
Locate the exposed portion of the LCD screen.
Use a wedge to free the LCD screen from the medal housing.
Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
Locate the 2 solder joints holding down the medal housing.
Remove the solder.
Place wick on solder.
Place solder iron on wick
The wick should be sandwiched between the iron and the solder.
Peel back the black tape from the metal housing.
Lift the metal housing from the left so that it hinges on its right side.
The metal housing is still loosely attached on its right side.
Locate black tab holding the LCD screen connector in the port.
Use wedge or fingernail to lift the black tab.
Pull the the LCD screen connector out of the port.
Turn the camera over.
Remove the screw holding the small green board.
Lift the small green board.
The small green board is still attached to the logic board via wires.
Locate the black tab holding the yellow cable in place.
Use a plastic opening tool or fingernail to lift the black tab.
Pull the yellow cable from the port.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
