跳转到主内容
Easyshare C813 Speaker Replacement
你所需要的
  1. Easyshare C813 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Easyshare C813 Speaker Replacement: 步骤 2 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 2 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 2 中的图像 3,3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Easyshare C813 Speaker Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Easyshare C813 Speaker Replacement: 步骤 4 中的图像 1,1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Easyshare C813 Speaker Replacement: 步骤 5 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 5 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 5 中的图像 3,3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  6. Easyshare C813 Speaker Replacement: 步骤 7 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 7 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 7 中的图像 3,3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  7. Easyshare C813 Speaker Replacement: 步骤 8 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 8 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 8 中的图像 3,3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  8. Easyshare C813 Speaker Replacement, Front Cover: 步骤 9 中的图像 1,2 Easyshare C813 Speaker Replacement, Front Cover: 步骤 9 中的图像 2,2
    • Open the battery door.
  9. Easyshare C813 Speaker Replacement: 步骤 10 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 10 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 10 中的图像 3,3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  10. Easyshare C813 Speaker Replacement: 步骤 11 中的图像 1,1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  11. Easyshare C813 Speaker Replacement, LCD: 步骤 12 中的图像 1,3 Easyshare C813 Speaker Replacement, LCD: 步骤 12 中的图像 2,3 Easyshare C813 Speaker Replacement, LCD: 步骤 12 中的图像 3,3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  12. Easyshare C813 Speaker Replacement: 步骤 13 中的图像 1,1
    • Remove the screw at the upper right corner of the metal housing.
  13. Easyshare C813 Speaker Replacement: 步骤 14 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 14 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 14 中的图像 3,3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  14. Easyshare C813 Speaker Replacement: 步骤 15 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 15 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 15 中的图像 3,3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  15. Easyshare C813 Speaker Replacement: 步骤 16 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 16 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 16 中的图像 3,3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  16. Easyshare C813 Speaker Replacement, Logic Board: 步骤 17 中的图像 1,1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  17. Easyshare C813 Speaker Replacement: 步骤 18 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 18 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 18 中的图像 3,3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  18. Easyshare C813 Speaker Replacement: 步骤 19 中的图像 1,2 Easyshare C813 Speaker Replacement: 步骤 19 中的图像 2,2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  19. Easyshare C813 Speaker Replacement: 步骤 20 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 20 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 20 中的图像 3,3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  20. Easyshare C813 Speaker Replacement: 步骤 21 中的图像 1,1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  21. Easyshare C813 Speaker Replacement: 步骤 22 中的图像 1,2 Easyshare C813 Speaker Replacement: 步骤 22 中的图像 2,2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  22. Easyshare C813 Speaker Replacement: 步骤 23 中的图像 1,3 Easyshare C813 Speaker Replacement: 步骤 23 中的图像 2,3 Easyshare C813 Speaker Replacement: 步骤 23 中的图像 3,3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
  23. Easyshare C813 Speaker Replacement, Speaker: 步骤 24 中的图像 1,1
    • Carefully pull the red and black wires located on the side of the camera connected to the speaker.
结论
团队
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G22
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,781
