跳转到主内容
EasySMX ESM-9110 Joystick Replacement
你所需要的
  1. EasySMX ESM-9110 Joystick Replacement, Backplate: 步骤 1 中的图像 1,3 EasySMX ESM-9110 Joystick Replacement, Backplate: 步骤 1 中的图像 2,3 EasySMX ESM-9110 Joystick Replacement, Backplate: 步骤 1 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
  2. EasySMX ESM-9110 Joystick Replacement: 步骤 2 中的图像 1,1
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
  3. EasySMX ESM-9110 Joystick Replacement: 步骤 3 中的图像 1,3 EasySMX ESM-9110 Joystick Replacement: 步骤 3 中的图像 2,3 EasySMX ESM-9110 Joystick Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
  4. EasySMX ESM-9110 Joystick Replacement, Joystick: 步骤 4 中的图像 1,2 EasySMX ESM-9110 Joystick Replacement, Joystick: 步骤 4 中的图像 2,2
    • Remove the four 10 mm Phillips screws from the motherboard.
    • Be careful removing the motherboard as the trigger buttons are attached loosely and can be inconvenient.
  5. EasySMX ESM-9110 Joystick Replacement: 步骤 5 中的图像 1,1
    • Remove the faulty joystick.
    • Clean the joystick if it is dirty and causing stick drift.
结论
Caleb French
于03/18/24注册
88 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-4, Konn Spring 2024 UMass Dartmouth, Team 2-4, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 51
总计 73
