跳转到主内容
EasySMX ESM-9100 Joystick Replacement
你所需要的
  1. EasySMX ESM-9100 Joystick Replacement, Bottom Case: 步骤 1 中的图像 1,1
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Joystick Replacement: 步骤 2 中的图像 1,3 EasySMX ESM-9100 Joystick Replacement: 步骤 2 中的图像 2,3 EasySMX ESM-9100 Joystick Replacement: 步骤 2 中的图像 3,3
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Joystick Replacement, Joystick: 步骤 3 中的图像 1,2 EasySMX ESM-9100 Joystick Replacement, Joystick: 步骤 3 中的图像 2,2
    • Firmly pull off the two analog sticks (joysticks) from the potentiometers.
    • Be careful when removing the analog sticks as excessive force can cause damage to the potentiometer.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2等其他人完成本指南。
Alex Vala
于03/19/24注册
746 声望
创作了6篇指南
团队
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 UMass Dartmouth, Team 4-4, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 45
总计 80
