跳转到主内容
EVGA x17 Clicker Replacement
你所需要的
  1. EVGA x17 Clicker Replacement, Clicker: 步骤 1 中的图像 1,1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Clicker Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips head screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Clicker Replacement: 步骤 3 中的图像 1,1
    • Remove the weight chamber cover.
  4. EVGA x17 Clicker Replacement: 步骤 4 中的图像 1,1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Clicker Replacement: 步骤 5 中的图像 1,2 EVGA x17 Clicker Replacement: 步骤 5 中的图像 2,2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Clicker Replacement: 步骤 6 中的图像 1,1
    • Carefully slide the middle section out.
  7. EVGA x17 Clicker Replacement: 步骤 7 中的图像 1,1
    • Remove the two screws from each clicker.
  8. EVGA x17 Clicker Replacement: 步骤 8 中的图像 1,1
    • Pop and slide out each clicker that needs to be replaced.
    • Clickers may need to be tugged forward in their slots to slide out.
    • Be extra careful removing clickers because the attachments are fragile.
结论
1指南评论
Tengo un Evga x17 y cuando quitó los sliders, encuentro unas pequeñas capas de plástico que tapan el acceso a los tornillos, ¿qué puedo hacer en ese caso?
Dennis Lopez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 354
