简介
The fan is a vital portion of the EVGA Supernova Nex 650 G Power Supply. This guide will show you how to dissassemble the power supply and fix it.
你所需要的
Disconnect all wires attached to the power supply before performing any actions on the power supply.
If the power supply was recently plugged into the wall, allow 10 minutes for the internal capacitors to discharge. '
Follow the wire to find where the fan connects to the board.
Using the needle nose pliers grab onto the plastic end of the wire and pull very lightly up on the plastic. Simultaneously, use the corner of the screwdriver to apply light pressure to the two holes to release the from being connected to the board. Doing this should allow for the the fan to be released from the board.
Remove the defective fan from the power supply.
3等其他人完成本指南。
一条评论
Hey, I appreciate the guide! Is the owner who created this guide still around? If so please comment back. I have a few questions in regards to this power supply that I think you could answer.
Thank you!
