简介
Follow this guide to remove and replace the striker plate on an EDCO Floor Stripper TS8 .75L (2017).
你所需要的
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
Slide the motor towards the front of the device to release tension in the belt."
Insert wheel chocks behind the wheels to ensure the device does not move or fall during the repair."
Use a 3/16 inch hex key to remove the three bolts securing the blade retainer.
Use a 1/8 inch hex key to loosen the two set screws on the lower flange bearing.
Use a mallet and an appropriately-sized brass punch to tap out the cam shaft assembly if you cannot remove it by hand.
Use a 9/16 inch socket to remove the four bolts securing the striker plate to the isolators.
2等其他人完成本指南。
