简介
Follow this guide to replace the belt on an EDCO Floor Stripper TS8 .75L (2017).
你所需要的
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
Slide the motor towards the front of the device to release tension in the belt."
另外一个人完成了本指南。
