跳转到主内容
EBK340 Powerhead Replacement
你所需要的
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: 步骤 1 中的图像 1,1
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: 步骤 2 中的图像 1,1
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: 步骤 3 中的图像 1,2 EBK340  Powerhead  Replacement, Replace Neck Joint: 步骤 3 中的图像 2,2
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
结论
另外一个人完成了本指南。
FolsomMaids Office
于10/09/19注册
167 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 167
