跳转到主内容
E-Cigarette Vaporizer Coil Replacement
你所需要的
  1. E-Cigarette Vaporizer Coil Replacement, Coil: 步骤 1 中的图像 1,2 E-Cigarette Vaporizer Coil Replacement, Coil: 步骤 1 中的图像 2,2
    • Pull up to remove the top cap from the IPV Mini II.
    • The unit may have hot surfaces.
    • Allow components to cool before starting.
  2. E-Cigarette Vaporizer Coil Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, turn counter clockwise to loosen the positive and negative screws.
    • Be sure that the IPV Mini II is powered off before proceeding.
  3. E-Cigarette Vaporizer Coil Replacement: 步骤 3 中的图像 1,1
    • Gently remove the burnt coil from the positive and negative screws.
  4. E-Cigarette Vaporizer Coil Replacement: 步骤 4 中的图像 1,1
    • Place the new coil into the holes underneath the positive and negative screws.
  5. E-Cigarette Vaporizer Coil Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips screwdriver, gently turn clockwise to tighten down the positive and negative screws onto the coil.
  6. E-Cigarette Vaporizer Coil Replacement: 步骤 6 中的图像 1,2 E-Cigarette Vaporizer Coil Replacement: 步骤 6 中的图像 2,2
    • Replace the top cap onto the IPV Mini II.
结论
To reverse the process, simply follow the instructions in reverse.
For more information visit https://bevapehappy.com/
12等其他人完成本指南。
rzgraves
于07/16/15注册
624 声望
撰写一个指南
团队
Texas Tech, Team 3-4, Rauch SU 2015 Texas Tech, Team 3-4, Rauch SU 2015 的会员
TTU-RAUCH-SU15S3G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 39
总计 5,214
