跳转到主内容
Dyson v6 Absolute Main Body Replacement
你所需要的
  1. Dyson v6 Absolute Main Body Replacement, Bin: 步骤 1 中的图像 1,1
    • Unplug the device.
  2. Dyson v6 Absolute Main Body Replacement: 步骤 2 中的图像 1,1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Main Body Replacement: 步骤 3 中的图像 1,1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Main Body Replacement: 步骤 4 中的图像 1,1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Main Body Replacement, Main Body: 步骤 5 中的图像 1,1
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Main Body Replacement: 步骤 6 中的图像 1,1
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Main Body Replacement: 步骤 7 中的图像 1,1
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Main Body Replacement: 步骤 8 中的图像 1,2 Dyson v6 Absolute Main Body Replacement: 步骤 8 中的图像 2,2
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
结论
12等其他人完成本指南。
团队
一条评论
The motorhead does not rotate or only works irregularly?
There are two little metal tabs sitting above the lever of the bin and are meant to make electrical contact to the wires running around the bin and down the wand to the motorhead to power the rotating brush. Those metal-tabs tend to get bend and/or their ends might have become dislocated out of their brackets.
Thanks for Your guide!!! It helped me to remove the Main Body from the Cyclone properly and get those metal-tabs back in place.
Robert Hoppe - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 186
总计 20,697
