跳转到主内容
Dyson v6 Absolute Battery Pack Replacement
你所需要的
  1. Dyson v6 Absolute Battery Pack Replacement, Bin: 步骤 1 中的图像 1,1
    • Unplug the device.
  2. Dyson v6 Absolute Battery Pack Replacement: 步骤 2 中的图像 1,1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Battery Pack Replacement: 步骤 3 中的图像 1,1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Battery Pack Replacement: 步骤 4 中的图像 1,1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Battery Pack Replacement, Battery Pack: 步骤 5 中的图像 1,1
    • Locate the screw on the battery pack.
    • Use a Phillips #2 screwdriver to unscrew the battery pack.
  6. Dyson v6 Absolute Battery Pack Replacement: 步骤 6 中的图像 1,1
    • Locate the screw on the device handle.
    • Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
  7. Dyson v6 Absolute Battery Pack Replacement: 步骤 7 中的图像 1,2 Dyson v6 Absolute Battery Pack Replacement: 步骤 7 中的图像 2,2
    • Pull the battery pack down and away from the device.
结论
137等其他人完成本指南。
团队
30条评论
very good article 10 out of 10
karl thiele - 回复
Nice article. Not too long or too short. Perfect pictures, too.
timlevin - 回复
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Meg Olhasque - 回复
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
Ellymck - 回复
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Beverley Mingo -
添加评论
浏览统计数据:
过去 24 小时: 39
过去 7 天: 369
过去 30 天: 1,773
总计 279,445
