跳转到主内容
Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement
你所需要的
  1. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Brush Bar: 步骤 1 中的图像 1,1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 2 中的图像 1,1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 3 中的图像 1,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 3 中的图像 2,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 3 中的图像 3,3
    • Pull the brush bar out of the housing.
  4. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: 步骤 4 中的图像 1,2 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: 步骤 4 中的图像 2,2
    • Turn the padlock key counterclockwise using the iFixit Opening Tool.
  5. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three front 1.4 cm torx screws using the T8 Torx screwdriver.
  6. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 6 中的图像 1,2 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 6 中的图像 2,2
    • Remove the upper plate once the padlock is unlocked.
  7. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 7 中的图像 1,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 7 中的图像 2,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 7 中的图像 3,3
    • Unscrew the top two corner 1.4 cm torx screws using the iFixit T8 Torx screwdriver.
    • Remove axie and roller after the screws are taken out.
  8. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 8 中的图像 1,1
    • Remove the drive assembly from vacuum housing.
    • Red wire connecting the drive assembly to housing.
  9. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 9 中的图像 1,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 9 中的图像 2,3 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 步骤 9 中的图像 3,3
    • Pop off the circular plating to remove the housing from the connection piece.
    • Red wire connects through the upper portion of the housing.
结论
7等其他人完成本指南。
Addie Hedge
于01/24/17注册
710 声望
创作了5篇指南
团队
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G6
4 名成员
创作了5篇指南
6条评论
can the direct drive motor unit be replaced rather than replacing the whole motor head. If so where can the motor be purchased from - I’ve internet searched without success!
Mikey - 回复
I am in the same boat, any luck finding just the direct drive motor ?
jerryd -
You can try ebay.
Joe - 回复
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
Paul Stewart - 回复
I’ve disassembled and see the black wire is broken! Has anyone done this?
lawrence - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 39
总计 14,183
