跳转到主内容
Dyson V6 Motorhead Motor Replacement
你所需要的
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: 步骤 1 中的图像 1,2 Dyson V6 Motorhead Motor Replacement, Collection Bin: 步骤 1 中的图像 2,2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: 步骤 2 中的图像 1,2 Dyson V6 Motorhead Motor Replacement: 步骤 2 中的图像 2,2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: 步骤 3 中的图像 1,3 Dyson V6 Motorhead Motor Replacement: 步骤 3 中的图像 2,3 Dyson V6 Motorhead Motor Replacement: 步骤 3 中的图像 3,3
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: 步骤 4 中的图像 1,1
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: 步骤 5 中的图像 1,2 Dyson V6 Motorhead Motor Replacement: 步骤 5 中的图像 2,2
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: 步骤 6 中的图像 1,2 Dyson V6 Motorhead Motor Replacement: 步骤 6 中的图像 2,2
    • Detach the motor from the remaining motor head assembly.
结论
10等其他人完成本指南。
Addie Hedge
于01/24/17注册
710 声望
创作了5篇指南
团队
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G6
4 名成员
创作了5篇指南
3条评论
really good can understand and not too technical
kelvin - 回复
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - 回复
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 52
总计 18,844
