跳转到主内容
Dyson V6 Motorhead Brush Bar Replacement
你所需要的
  1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: 步骤 1 中的图像 1,1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Brush Bar Replacement: 步骤 2 中的图像 1,1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Brush Bar Replacement: 步骤 3 中的图像 1,3 Dyson V6 Motorhead Brush Bar Replacement: 步骤 3 中的图像 2,3 Dyson V6 Motorhead Brush Bar Replacement: 步骤 3 中的图像 3,3
    • Pull the brush bar out of the housing.
结论
3等其他人完成本指南。
Addie Hedge
于01/24/17注册
710 声望
创作了5篇指南
团队
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G6
4 名成员
创作了5篇指南
4条评论
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - 回复
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - 回复
I have the same problem and I never signed up for the warranty.
Donna Sweeney - 回复
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 39
总计 21,803
