跳转到主内容
Dyson Supersonic HD03 Hairdryer Filter Replacement
你所需要的
  1. Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: 步骤 1 中的图像 1,2 Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: 步骤 1 中的图像 2,2
    • Unplug the hairdryer to avoid further hazard.
  2. Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 2 中的图像 1,2 Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 2 中的图像 2,2
    • Remove the dirty filter cage by twisting the filter towards the left.
    • The filter cage will be unlocked when the red dot matches the white thin circle.
    • Do not run your hairdryer without a filter cage.
  3. Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 3 中的图像 1,1
    • Soak the filter cage in dish soap and warm water for at least 30 minutes.
    • You can leave the filter in for multiple hours or overnight if it's especially dirty.
    • Use the supplied filter cleaning brush or any other cleaning tool to vigorously scrub the soaked filter cage.
    • Be sure to remove all blockages.
  4. Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 5 中的图像 1,1
    • Rinse and dry your filter cage.
    • Check that the filter cage is clean by holding it up to the light - you should be able to see light through it. If you can't, repeat the previous step.
  5. Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 6 中的图像 1,2 Dyson Supersonic HD03 Hairdryer Filter Replacement: 步骤 6 中的图像 2,2
    • Insert the filter back into the filter cage and install the filter cage back onto the device.
    • The filter cage will be locked when the red dot matches the white filled circle.
结论
另外一个人完成了本指南。
Huan-Che Hsu
于09/18/21注册
192 声望
撰写一个指南
团队
York University, Team F-14, Woodhouse Fall 2021 York University, Team F-14, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG14
1 名成员
创作了1篇指南
一条评论
My Dyson hair dryer has quitting every 30 seconds - apparently overheating. It was very easy to remove the filter cage and wipe the filter clean. Problem solved!
Jimjar - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 72
总计 4,131
