简介
If, after consulting the troubleshooting page, you believe your oscillation motor has blown, this guide will walk you through accessing it to do your own repair/replacement. The oscillation motor is wired directly into the devices main circuitry and thus requires knowledge and experience to replace. This guide will simply cover how to access and remove it.
你所需要的
Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
即将完成!
终点
另外一个人完成了本指南。
