跳转到主内容
Dyson Handheld Maintenance - Beater Bar
你所需要的
    • Aside the clearly visible indicators that there is an issue (debris wrapped around the bar, etc) you should be able to see through the attachment from one end to the other with a bit of manipulation.
    • This specimen is not in a happy place - no daylight is visible, the roller is heavily clogged, and debris is blocking any airflow that would usually be present. In its current state - this attachment is useless.
    • To perform this exorcism, I will be using Scissors, a few Cable-Ties, some Vinyl Gloves, and a sensibly sized coin. For those of us in the UK, a 2p coin works perfectly here.
    • Using your coin of choice, open up the compartment to the side of the beater bar.
    • The bar itself, and the retainer clip should come apart, and allow you to pull the beater bar roller out completely
    • Using your scissors, run underneath any hair, carpet, or other threads that may have wrapped around the roller
    • An easy way is to follow the lines between any of the brushes (you do not want to cut theses) - and slice through anything that shouldn't be there.
    • Once everything has been freed up, you can tease everything out by hand in clumps. Here I've just gone along the brushes and pulled out anything that should not be there.
    • There we go - that looks a bit better!
结论
Luke Wetherall
于01/02/16注册
101 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,417
