跳转到主内容
Dyson DC58 Cyclone Replacement
你所需要的
  1. Dyson DC58 Cyclone Replacement, Bin: 步骤 1 中的图像 1,1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Cyclone Replacement: 步骤 2 中的图像 1,1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Cyclone Replacement: 步骤 3 中的图像 1,1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Cyclone Replacement: 步骤 4 中的图像 1,2 Dyson DC58 Cyclone Replacement: 步骤 4 中的图像 2,2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Cyclone Replacement, Main Body: 步骤 5 中的图像 1,1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Cyclone Replacement: 步骤 6 中的图像 1,2 Dyson DC58 Cyclone Replacement: 步骤 6 中的图像 2,2
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Cyclone Replacement: 步骤 7 中的图像 1,1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
  8. Dyson DC58 Cyclone Replacement, Cyclone: 步骤 8 中的图像 1,2 Dyson DC58 Cyclone Replacement, Cyclone: 步骤 8 中的图像 2,2
    • Use the metal spudger placed between the black rim and the purple rim to separate the purple screen cover from the cyclone body.
    • Pry all the way around the screen cover.
  9. Dyson DC58 Cyclone Replacement: 步骤 9 中的图像 1,1
    • Use a T9 screw driver to remove the five 14mm screws around the edge of the cyclone body.
  10. Dyson DC58 Cyclone Replacement: 步骤 10 中的图像 1,2 Dyson DC58 Cyclone Replacement: 步骤 10 中的图像 2,2
    • Pull down on the black tube-like part of the silver cyclone body to remove it from the cyclone of the Dyson.
    • You may need to wiggle the tube as you are pulling down to loosen the pieces apart.
结论
19等其他人完成本指南。
团队
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G4
4 名成员
创作了19篇指南
11条评论
Great job, very useful thanks
Don - 回复
Fantastic thanks!!!!
robh - 回复
Very helpful indeed.
macx - 回复
Thanks. Had to wash out the dog smell. This did the trick.
David Parsons - 回复
Thanks. Had to wash out the dog smell. This did the trick when new filters wouldn't. Shame on Dyson for not making an easier to clean vacuum.
David Parsons - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 145
总计 23,663
