跳转到主内容
Dyson DC58 Bin Replacement
  1. Dyson DC58 Bin Replacement, Bin: 步骤 1 中的图像 1,1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Bin Replacement: 步骤 2 中的图像 1,1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Bin Replacement: 步骤 3 中的图像 1,1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Bin Replacement: 步骤 4 中的图像 1,2 Dyson DC58 Bin Replacement: 步骤 4 中的图像 2,2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
结论
3等其他人完成本指南。
Ian Sloan
于09/17/15注册
161 声望
撰写一个指南
团队
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G4
4 名成员
创作了19篇指南
2条评论
The bin is stuck and won’t come off, although I have followed the directions above.
Marcy Altimano - 回复
I think the reassembly instructions should be numbered “Step 5” and printed right below Step 4. They aren’t that easy to see.
Mary Miraglia - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 12,897
