跳转到主内容
Dyson DC39 Origin Steering Assembly Replacement
你所需要的
  1. Dyson DC39 Origin Steering Assembly Replacement, Bin: 步骤 1 中的图像 1,3 Dyson DC39 Origin Steering Assembly Replacement, Bin: 步骤 1 中的图像 2,3 Dyson DC39 Origin Steering Assembly Replacement, Bin: 步骤 1 中的图像 3,3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 步骤 2 中的图像 1,3 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 步骤 2 中的图像 2,3 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 步骤 2 中的图像 3,3
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Steering Assembly Replacement: 步骤 3 中的图像 1,3 Dyson DC39 Origin Steering Assembly Replacement: 步骤 3 中的图像 2,3 Dyson DC39 Origin Steering Assembly Replacement: 步骤 3 中的图像 3,3
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
结论
另外一个人完成了本指南。
Luke Matusiak
于04/26/17注册
479 声望
创作了3篇指南
团队
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G6
3 名成员
创作了6篇指南
一条评论
Thank you, thank you, thank you!
Robin Hill - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 717
