跳转到主内容
Dyson DC24 Dust Bin O-Ring Replacement
你所需要的
  1. Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 步骤 1 中的图像 1,3 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 步骤 1 中的图像 2,3 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 步骤 1 中的图像 3,3
    • Remove the dirt container by clicking on the red button.
    • Pull away the container from the main body.
  2. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 2 中的图像 1,2 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 2 中的图像 2,2
    • Push on the gray release tab on the back of the container.
    • This separates the clear container piece from the filter/suction region.
  3. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 3 中的图像 1,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 3 中的图像 2,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 3 中的图像 3,3
    • Grab the top filter piece and pull the clear tab out towards you and this should release the top chamber and reveal a filter.
  4. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 4 中的图像 1,1
    • Remove the filter from the dust container.
    • Depending on the level of cleanliness of the filter you will need to clean it or order a new one.
  5. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 5 中的图像 1,2 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 5 中的图像 2,2
    • Use a T15 screwdriver to carefully unscrew and remove five 19.1 mm screws.
    • Make sure to keep the red plastic piece. When putting the pieces back together you will need to orient the red plastic piece properly (see arrow for piece).
  6. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 6 中的图像 1,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 6 中的图像 2,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 6 中的图像 3,3
    • On the bottom of the piece that lifts up, you will see a hexagonal divider ring. This can be removed by lifting from an edge and pulling.
  7. Dyson DC24 Dust Bin O-Ring Replacement: 步骤 7 中的图像 1,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 7 中的图像 2,3 Dyson DC24 Dust Bin O-Ring Replacement: 步骤 7 中的图像 3,3
    • On the bottom piece, there is a second more traditional-looking o-ring. Remove this by grabbing the ring, pulling it out towards you, and down.
结论
With the completion of step 7, you are done. To reassemble your device, follow these instructions in reverse order.
Angel Verdejo
于01/26/23注册
145 声望
撰写一个指南
团队
UC Davis, Team 1-4, Morris Winter 2023 UC Davis, Team 1-4, Morris Winter 2023 的会员
UCD-MORRIS-W23S1G4
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 193
