跳转到主内容
Dyson DC24 Ball Lower Small Bearing Replacement
你所需要的
  1. Dyson DC24 Ball Lower Small Bearing Replacement, DC24 Ball's Lower Small Bearing: 步骤 1 中的图像 1,1
    • Recline vacuum all the way to expose as much of the ball as possible.
  2. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 2 中的图像 1,1
    • Using a Torx screwdriver, remove the four screws that hold both sides of the ball together.
  3. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 3 中的图像 1,1
    • Remove the end of the lower duct hose to reveal a torx screw.
    • Remove the screw that holds the motor to the axel.
  4. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 4 中的图像 1,2 Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 4 中的图像 2,2
    • Remove the three torx screws on the otherside.
    • Then remove the cover which will reveal some power cables.
    • Then remove the last screw that holds the motor to the axel.
  5. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 5 中的图像 1,1
    • Remove the post motor filter.
    • Carefully pull the axel out of its hole and down.
  6. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 6 中的图像 1,2 Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 6 中的图像 2,2
    • Place the new bearing on the axel. (It doesn't matter which way it goes on)
  7. Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 7 中的图像 1,2 Dyson DC24 Ball Lower Small Bearing Replacement: 步骤 7 中的图像 2,2
    • When reassembling, it is easiest to put the vacuum in its upright position to insert the axel screws.
    • The red arrow points to the type of torx screws that hold the motor in place while the orange arrow points to the type that hold the orange ball together.
    One thing to note. Is the hose that is disconnected on step 6. Gets clogged often if you have long haired dogs. And in some cases there is another spot if you follow that around that has a u joint and it clogs often as
    GKJarhead - 回复
结论
2等其他人完成本指南。
ForumHermit
于08/16/13注册
1,730 声望
创作了2篇指南
4条评论
When replacing the bearings, is there only one small bearing set to replace or are there two sets, one on each side? If there are two, should they both be replaced?
Josh McCanless - 回复
I believe there is only one you need to replace. This was a common issue with the DC24.
ForumHermit -
Thanks for the guide. $20 for the part and 20 minutes later, I saved myself $400.
You, sir, are awesome.
Bless you for the guide.
Josh McCanless - 回复
No worries! I made this guide to help people do that exact thing.
ForumHermit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 5,416
