跳转到主内容
Dyson Cinetic Big Ball Animal Upright Filter Replacement
你所需要的
  1. Dyson Cinetic Big Ball Animal Upright Filter Replacement, Filter: 步骤 1 中的图像 1,1
    • Start on the left side of the Dyson Ball.
  2. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 2 中的图像 1,1
    • Remove the center 18mm screw from the Dyson Ball, then remove the covering.
  3. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 3 中的图像 1,1
    • Next, remove the upper right 18mm screw along the perimeter of the circle.
  4. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 4 中的图像 1,1
    • Continuing clockwise along the path, remove the next 18mm screw.
  5. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 5 中的图像 1,1
    • Remove the next 18mm screw at the lower edge of the circle.
  6. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 6 中的图像 1,1
    • Then remove the final 18mm screw in the center. Once these have all been unscrewed, remove the filter with the cover. The filter and the cover should be attached to each other.
  7. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 7 中的图像 1,1
    • Gently unclip the cover from the filter.
  8. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 步骤 8 中的图像 1,1
    • This is how it should look once the covering has been removed.
结论
To reassemble your device, follow these instructions in reverse order. The Dyson has two filters, so if the problem has not been resolved, you may have to repeat this process on the other side.
8等其他人完成本指南。
Karla Sunjara
于01/24/17注册
891 声望
创作了5篇指南
团队
Cal Poly, Team S13-G1, Banghart Winter 2017 Cal Poly, Team S13-G1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G1
3 名成员
创作了10篇指南
4条评论
Can this filter be washed?
mariabrooke0828 - 回复
No it's not a washable filter and is supposed to last the life of the machine - hmm… still going to get clogged with fine dust though so yif contact Dyson! They don't last and the increased clogging can reduce the life of the motor.
Scott -
Can you buy a replacement filter?? Thank you.
Lori Turner - 回复
I’ve bought a second hand dyson big ball cleaner. It’s stinks of dogs. How can I take it apart and clean it?
Joyce haras - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 48
过去 30 天: 194
总计 31,533
