跳转到主内容
Dyson Cinetic Big Ball Animal Upright Brushbar Replacement
你所需要的
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement, Brushbar: 步骤 1 中的图像 1,1
    • Lay the vacuum on its back so you can see the Dyson from underneath.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 2 中的图像 1,1
    • Underneath the Dyson locate the red plastic tab.
    • Pull out the red tab
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 3 中的图像 1,1
    • Detach the brush bar and frame from the Dyson Ball.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 4 中的图像 1,1
    • Lay the brushbar flat as if it was vacuuming.
    • Locate the two red tabs on either side of the brushbar frame.
    • Lift up the red tabs and the brushbar frame will come off.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 5 中的图像 1,1
    • Place the Dyson brushbar on its back.
    • Locate the four 15mm screws in each corner of the black plastic.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 6 中的图像 1,3 Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 6 中的图像 2,3 Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: 步骤 6 中的图像 3,3
    • Unscrew the 15mm screws in all four corners of the brushbar.
    • Remove the brushbar and replace it with a new brushbar.
结论
4等其他人完成本指南。
Karla Sunjara
于01/24/17注册
891 声望
创作了5篇指南
团队
Cal Poly, Team S13-G1, Banghart Winter 2017 Cal Poly, Team S13-G1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G1
3 名成员
创作了10篇指南
3条评论
okay I removed the screws the brushbar doesnt come out .. HOW do I remove the brushbar? That would be very helpful
freshveg - 回复
I have the same question
sansan722 - 回复
If you look toward the center part on each side of the belt container you'll see 2 little clear tabs sticking out on each of the inner parts of the purple brush. Use a flat head screw driver and gently push each of those tabs in (obviously one side of roller then the other side) as you pull outward on the outer side of the roller (it's a 2 piece roller)
cory_duffin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 28
总计 8,000
