跳转到主内容
Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
你所需要的
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: 步骤 1 中的图像 1,1
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: 步骤 2 中的图像 1,1
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
结论
Allison Turnbaugh
于01/25/17注册
213 声望
创作了2篇指南
团队
Cal Poly, Team 9-5, Banghart Winter 2017 Cal Poly, Team 9-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G5
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 2,431
