跳转到主内容
Dyson Ball Multi Floor Upright Wheels Replacement
你所需要的
  1. Dyson Ball Multi Floor Upright Wheels Replacement, Wheels: 步骤 1 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement, Wheels: 步骤 1 中的图像 2,2
    • Twist the purple center circle counter clockwise until loose. This will leave the entire grey covering loosened.
  2. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 2 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 2 中的图像 2,2
    • Place both hands on the filter itself and twist counterclockwise until loosened.
    • Once loosened, pull up on the entire side filter and it will easily come apart from the main vacuum stand for replacement.
  3. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 3 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 3 中的图像 2,2
    • Place a pair of small needle-nose pliers in the small gray center of the side hemisphere. Twist counterclockwise and pull the small center piece out.
    • Reinsert the small needle nose pliers into the center piece that is now exposed. Twist counterclockwise until you can pull the entire hemisphere off.
  4. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 4 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 4 中的图像 2,2
    • Remove the two 15 mm T-10 black screws on the side of the wheel.
    • After the 15 mm T-10 black screws are removed, you will be able to remove the half circle that covers the wheel.
  5. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 5 中的图像 1,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 5 中的图像 2,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 5 中的图像 3,3
    • Remove the six 15 mm T-10 black screws on the left side of the vacuum.
    • Once this is done, remove the interior cover.
  6. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 6 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 6 中的图像 2,2
    • Remove the four 10 mm T-10 silver screws on the bottom of the ball of the vacuum and the two lower 15mm T-15 silver screws.
    • Firmly grab the white, three-pronged piece on the left side and pull it off.
    • Push off the right side of the piece by placing your thumbs where the first two 15 mm T-10 black screws originally were.
    • Remove the bottom piece.
  7. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 7 中的图像 1,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 7 中的图像 2,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 7 中的图像 3,3
    • Use the flat headed metal tool to press the tab and release the last part of the outer shell
    • This tab is difficult to release so some force is necessary
    • This part of the shell will now release and slide off easily
  8. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 8 中的图像 1,2 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 8 中的图像 2,2
    • Remove the 15 mm T-10 black screw that is located where the wires enter into the vacuum using a Phillips 0 screwdriver.
    • Press into the notches on either side of the vacuum by using your thumbs. Do this for both sides of the vacuum.
    • Pull off the protective covering of the circuit board in order to reveal the circuit board.
  9. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 9 中的图像 1,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 9 中的图像 2,3 Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 9 中的图像 3,3
    • Pull off the piece that includes the circuit board on it.
    • Unscrew the final 10 mm T-10 black screw on the white circle using a Phillips 0 screwdriver.
    • Pull off that side gently using your fingers, then pull off the opposite side as well.
  10. Dyson Ball Multi Floor Upright Wheels Replacement: 步骤 10 中的图像 1,1
    • After the final screw is removed, pull off the wheels on both sides of the vacuum.
结论
5等其他人完成本指南。
Nicole Abraham
于01/26/17注册
839 声望
创作了5篇指南
团队
Cal Poly, Team 21-2, Maness Winter 2017 Cal Poly, Team 21-2, Maness Winter 2017 的会员
CPSU-MANESS-W17S21G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 52
总计 7,408
