跳转到主内容
Dyson Ball Multi Floor Upright Electrical Cord Replacement
你所需要的
  1. Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 步骤 1 中的图像 1,2 Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 步骤 1 中的图像 2,2
    • Press the red button on the back to release the hose and allow for easy access to the back
  2. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the four 15 mm T-10 black screws now showing in the back of the vacuum hose track, using the Phillips 0 screwdriver found in the iFixit tool kit.
  3. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 3 中的图像 1,2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 3 中的图像 2,2
    • Use a pair of needle nosed pliers to press both tabs simultaneously.
    • Hold onto the front hatch while doing this or it will fall off and a spring and lever will fall out with it.
    • Remove the hatch carefully exposing the wiring underneath
  4. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 4 中的图像 1,2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 4 中的图像 2,2
    • Remove the black wire from its connection near the top of the hatch
  5. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 5 中的图像 1,2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 5 中的图像 2,2
    • Open the black box near the bottom of the hatch area using the two push tabs
    • This exposes the white wire's connection
  6. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 6 中的图像 1,1
    • Disconnect the white wire using the small metal tab.
    • Do not damage the wire during the process.
  7. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 步骤 7 中的图像 1,1
    • Pull vertically on the grey cord now and it should separate from the rest of the vacuum
    • To replace the cord, slide the new grey cord into place and connect the two wires again then complete the steps in reverse
结论
另外一个人完成了本指南。
Nicole Abraham
于01/26/17注册
839 声望
创作了5篇指南
团队
Cal Poly, Team 21-2, Maness Winter 2017 Cal Poly, Team 21-2, Maness Winter 2017 的会员
CPSU-MANESS-W17S21G2
4 名成员
创作了10篇指南
一条评论
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
Jordan Adams - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 54
总计 3,657
