简介
If you are using your Dyson Multi Floor Upright and there are problems or damages to the electrical cord that are causing issues with the power of your vacuum, the problem is most likely the electrical cord. The best solution to this problem is to replace the electrical cord.
你所需要的
Press the red button on the back to release the hose and allow for easy access to the back
另外一个人完成了本指南。
一条评论
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
