跳转到主内容
Dyson Ball Animal Power Cord Replacement
你所需要的
  1. Dyson Ball Animal Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Turn off and unplug the vacuum.
    • Remove the vacuum canister from the front of the vacuum.
  2. Dyson Ball Animal Power Cord Replacement: 步骤 2 中的图像 1,1
    • Flip the vacuum around and remove the hose so it is not blocking the back of the vacuum.
  3. Dyson Ball Animal Power Cord Replacement: 步骤 3 中的图像 1,3 Dyson Ball Animal Power Cord Replacement: 步骤 3 中的图像 2,3 Dyson Ball Animal Power Cord Replacement: 步骤 3 中的图像 3,3
    • There are four 15mm screws that must be removed with a Torx T15 screwdriver.
  4. Dyson Ball Animal Power Cord Replacement: 步骤 4 中的图像 1,3 Dyson Ball Animal Power Cord Replacement: 步骤 4 中的图像 2,3 Dyson Ball Animal Power Cord Replacement: 步骤 4 中的图像 3,3
    • After all the screws are released there are two tabs that must be pressed in and towards the center.
    • The tabs can be pressed in one at a time but may require some force.
  5. Dyson Ball Animal Power Cord Replacement: 步骤 5 中的图像 1,2 Dyson Ball Animal Power Cord Replacement: 步骤 5 中的图像 2,2
    • After removing the two tabs gently pull the face off the power supply.
  6. Dyson Ball Animal Power Cord Replacement: 步骤 6 中的图像 1,1
    • Follow the black cord from the power cord.
    • Pinch the plastic piece.
    • Remove from the metal tongue.
    • When removing the cords, grab them from the plastic parts and not the cord.
  7. Dyson Ball Animal Power Cord Replacement: 步骤 7 中的图像 1,3 Dyson Ball Animal Power Cord Replacement: 步骤 7 中的图像 2,3 Dyson Ball Animal Power Cord Replacement: 步骤 7 中的图像 3,3
    • There is also a black case that needs to be opened in order to remove the power cord.
    • After opening the case pull apart the wire and attach the new wire.
    • Again, make sure that you are pulling from the heads of the wires and not the wires themselves.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G5
4 名成员
创作了16篇指南
3条评论
Great tutorial! The pictures were awesome, I replaced my cord in about 15 minutes thanks to this post. The only thing you might want to add is the gray switch with the spring. Mine fell out while I was trying to put the unit back together and I had to research how it went back together correctly. Thanks again!
Jim
Jim Knox - 回复
I had the same spring lever issue. This video shows how to replace them.
https://youtu.be/CLk1Zu6nREk
Robert W Marvin - 回复
Thank you for the YouTube link on the button reassembly. I should have expected it to be sitting loaded when I disassembled it.
chuckparent -
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 87
过去 30 天: 397
总计 32,953
