跳转到主内容
Dyson Ball Animal Power Button Replacement
你所需要的
  1. Dyson Ball Animal Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Dyson Ball Animal Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: 步骤 2 中的图像 1,1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: 步骤 3 中的图像 1,2 Dyson Ball Animal Power Button Replacement: 步骤 3 中的图像 2,2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: 步骤 4 中的图像 1,2 Dyson Ball Animal Power Button Replacement: 步骤 4 中的图像 2,2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: 步骤 5 中的图像 1,3 Dyson Ball Animal Power Button Replacement: 步骤 5 中的图像 2,3 Dyson Ball Animal Power Button Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: 步骤 6 中的图像 1,2 Dyson Ball Animal Power Button Replacement: 步骤 6 中的图像 2,2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: 步骤 7 中的图像 1,2 Dyson Ball Animal Power Button Replacement: 步骤 7 中的图像 2,2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
结论
4等其他人完成本指南。
Hank Wai
于05/07/17注册
166 声望
撰写一个指南
团队
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 52
总计 6,796
