跳转到主内容
Dyson Ball Animal Brushbar Replacement
你所需要的
  1. Dyson Ball Animal Brushbar Replacement, Brushbar: 步骤 1 中的图像 1,2 Dyson Ball Animal Brushbar Replacement, Brushbar: 步骤 1 中的图像 2,2
    • Turn off and unplug the vacuum.
  2. Dyson Ball Animal Brushbar Replacement: 步骤 2 中的图像 1,2 Dyson Ball Animal Brushbar Replacement: 步骤 2 中的图像 2,2
    • Recline the vacuum on its back and position the brushbar up in the air.
  3. Dyson Ball Animal Brushbar Replacement: 步骤 3 中的图像 1,2 Dyson Ball Animal Brushbar Replacement: 步骤 3 中的图像 2,2
    • Pull the red ring around the base of the brush head down and away from the body.
  4. Dyson Ball Animal Brushbar Replacement: 步骤 4 中的图像 1,1
    • Pull the brushbar out from the vacuum.
  5. Dyson Ball Animal Brushbar Replacement: 步骤 5 中的图像 1,1
    • Pull up the red tabs on the top of the brushbar.
  6. Dyson Ball Animal Brushbar Replacement: 步骤 6 中的图像 1,1
    • Remove the front panel of the brushbar.
  7. Dyson Ball Animal Brushbar Replacement: 步骤 7 中的图像 1,3 Dyson Ball Animal Brushbar Replacement: 步骤 7 中的图像 2,3 Dyson Ball Animal Brushbar Replacement: 步骤 7 中的图像 3,3
    • Remove the four screws with a Torx T10 Screwdriver.
  8. Dyson Ball Animal Brushbar Replacement: 步骤 8 中的图像 1,2 Dyson Ball Animal Brushbar Replacement: 步骤 8 中的图像 2,2
    • Lift the brushbar away from the housing while pulling it out to the side.
    • This may take some force and wiggling.
结论
21等其他人完成本指南。
Mairead Nye
于05/07/17注册
426 声望
撰写一个指南
团队
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G5
4 名成员
创作了16篇指南
15条评论
I'm like to know if this works for the Dyson ball animal2 as well
Jean Riehle - 回复
It does work
ade 23 -
We used this guide to clean the brushbar assembly of the DC41 animal too. Thank you SO MUCH for writing it!!! We’d never have tried pulling the bar off sideways.
Anthony Clark - 回复
Thanks to MaireadNye for the easy to follow guide. I used this to remove and clean the brush bar and its housing on a Dyson Animal 2 upright vacuum. The four screws securing the brush bar were not T10 Torx, but rather Phillips head, so no big deal. What took the longest amount of time was searching for my Torx tools before I began, which is unlike me. I usually grab tools as I go, but since only one was required, I decided to (unnecessarily) have it ready to go. I used vinegar first to get out a soy sauce type smell, but dish soap was what worked. Thanks again!
(And thanks to Dyson for making stuff like this user-friendly!)
renee marie - 回复
what is the part and part number of the wheel in between the brush bar?
Jerry Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 124
过去 30 天: 657
总计 82,726
