跳转到主内容
Dynex DX-WBRDVD1 WiFi Antenna Replacement
你所需要的
  1. Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: 步骤 1 中的图像 1,2 Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 WiFi Antenna Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 WiFi Antenna Replacement: 步骤 3 中的图像 1,1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: 步骤 4 中的图像 1,3 Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: 步骤 4 中的图像 2,3 Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: 步骤 4 中的图像 3,3
    • Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
    • Use a pointed tool and press down on the indents on both sides of the clip to loosen.
  5. Dynex DX-WBRDVD1 WiFi Antenna Replacement: 步骤 5 中的图像 1,1
    • Remove the two 7mm screws from both sides of the antenna.
  6. Dynex DX-WBRDVD1 WiFi Antenna Replacement: 步骤 6 中的图像 1,2 Dynex DX-WBRDVD1 WiFi Antenna Replacement: 步骤 6 中的图像 2,2
    • Slide the antenna inwards and gently remove.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 268
