跳转到主内容
Dynex DX-WBRDVD1 Power Supply Board Replacement
你所需要的
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 步骤 1 中的图像 1,2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 3 中的图像 1,1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 步骤 4 中的图像 1,2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 步骤 4 中的图像 2,2
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 5 中的图像 1,2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 5 中的图像 2,2
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 6 中的图像 1,2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 6 中的图像 2,2
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 7 中的图像 1,2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 7 中的图像 2,2
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: 步骤 8 中的图像 1,1
    • Remove the power supply board.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 689
