跳转到主内容
Dynex DX-WBRDVD1 Optical Drive Replacement
你所需要的
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: 步骤 1 中的图像 1,2 Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,2 Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 5 中的图像 1,2 Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 6 中的图像 1,2 Dynex DX-WBRDVD1 Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 388
