跳转到主内容
Dymo LabelManager 280 Keyboard Replacement
你所需要的
  1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: 步骤 1 中的图像 1,2 Dymo LabelManager 280 Keyboard Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Keyboard Replacement: 步骤 2 中的图像 1,2 Dymo LabelManager 280 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feets
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Keyboard Replacement: 步骤 3 中的图像 1,2 Dymo LabelManager 280 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
  4. Dymo LabelManager 280 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Dymo LabelManager 280 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove the rubber keyboard.
结论
Steven Nguyen
于02/08/16注册
431 声望
创作了3篇指南
团队
USF Tampa, Team 6-5, Eyestone Spring 2016 USF Tampa, Team 6-5, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G5
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,253
