跳转到主内容
Durofix RV332 Motor Replacement
你所需要的
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: 步骤 1 中的图像 1,1
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: 步骤 2 中的图像 1,2 Durofix RV332 Motor Replacement: 步骤 2 中的图像 2,2
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: 步骤 3 中的图像 1,2 Durofix RV332 Motor Replacement: 步骤 3 中的图像 2,2
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: 步骤 4 中的图像 1,1
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: 步骤 5 中的图像 1,3 Durofix RV332 Motor Replacement: 步骤 5 中的图像 2,3 Durofix RV332 Motor Replacement: 步骤 5 中的图像 3,3
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: 步骤 6 中的图像 1,1
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
结论
Tyler Vincent
于02/24/14注册
479 声望
创作了4篇指南
团队
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G5
3 名成员
创作了5篇指南
一条评论
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 813
